I am using some template canvases bound to a memory tag DataSet for their layout, but every time I open my projects in Ignition Designer I get this error. Everything seems to work fine on the client side but this is a nuisance I cannot figure out. Is there any way to avoid this when I launch the project in designer?
java.lang.ClassCastException: Cannot coerce value ‘-1’ into type: interface com.inductiveautomation.ignition.common.Dataset
at com.inductiveautomation.ignition.common.TypeUtilities.coerce(TypeUtilities.java:1242)
at com.inductiveautomation.factorypmi.application.binding.AbstractPropertyAdapter.setQValue(AbstractPropertyAdapter.java:224)
at com.inductiveautomation.factorypmi.application.binding.AbstractPropertyAdapter.updateValue(AbstractPropertyAdapter.java:264)
at com.inductiveautomation.factorypmi.application.binding.ExpressionPropertyAdapter.runExpression(ExpressionPropertyAdapter.java:88)
at com.inductiveautomation.factorypmi.application.binding.ExpressionPropertyAdapter$1.run(ExpressionPropertyAdapter.java:58)
at com.inductiveautomation.ignition.client.util.EDTUtil$ProcessQueue.run(EDTUtil.java:112)
at java.awt.event.InvocationEvent.dispatch(Unknown Source)
at java.awt.EventQueue.access$400(Unknown Source)
at java.awt.EventQueue$2.run(Unknown Source)
at java.security.AccessControlContext$1.doIntersectionPrivilege(Unknown Source)
Ignition v7.8.0 (b2015101414)
Java: Sun Microsystems Inc. 1.6.0_43
