Template canvas set gap to 0
Hi there,
I’m trying to use the Template Canvas Layout Positioning mode to put a few templates in a row.
Its a fairly simple application, there will only be one row of components, only two different templates will be used.
Without applying any special layout settings, i get gaps between the components.
How can i reduce these to 0? Or small enough that the components actually touch?
I’ve had a look through these MIG component resources, but applying all sorts of combinations of “gap” and “gapx” didn’t really do anything for me.
http://migcalendar.com/miglayout/cheatsheet.html
https://stackoverflow.com/questions/14389447/set-default-gap-to-0-in-mig-layout
Non-zero values for min:preferred:max gap size seem to work, as below:
Note: I can certainly use the Absolute Positioning method to get what i want, but i would like to avoid having to manually calculate all the position parameters if possible.
Change the ‘Layout Constraints’ property of the template canvas itself to include gap 0:
Ah perfect thanks, i was wondering how to control the global settings. That did the trick.
@paul-griffith do you know how to return a “{” inside a mysql select query so that the paramters part of the dataset can be returned via a query?
Struggling a bit to get that final piece of the puzzle sorted so that i can generate this dataset from a mysql query.
It seems like mysql treats “{}” characters as delimeters or something. Or something gets converted to a “path” in mysql.
Maybe try JSON_QUOTE(column) in your query?
https://database.guide/json_quote-how-to-escape-characters-in-strings-used-as-json-values-in-mysql/
Thanks for the point in the right direction.
using JSON_OBJECT works, as per this manual page:
(MySQL :: MySQL 8.0 Reference Manual :: 11.5 The JSON Data Type)
	JSON_OBJECT('cut_index',row_id) AS "parameters",
