Is there a way to know which parameter of a user data types is used in a template?
As an example rockwell as the CTRL-U key that give you all the param or expression used in the selection of objects.
regards
regards
There’s no hotkey for that, but we do have a Show Dependencies option in the designer that will draw arrows between components that are bound to each other. You can access it from the designer Menubar under View -> Dependencies -> Show All
