I'm running into a graphical bug when using template repeaters. Images being used as indicators are being resized inconsistently. An image is below for reference. The three indicators in the top have been resized to match the three across the bottom. Sometimes, none of them resize, and sometimes a random selection does.
I can avoid this by manually resizing the image to match the desired pixel resolution in another program then re-importing the image back into ignition, but that seems excessive. Is there a known fix for this issue, or even a way to avoid it?
It's the inconsistency that was most confusing. Of the half dozen images in the template, about two or three of them are consistently sized wrong, but it's not the same ones each time.
This one is probably a good one to call support for. If you can share your screen with them they can look the system over more thoroughly and find the more obscure things that may be causing the problem.
