Template not opening in Designer
I'm having trouble opening a template in the designer. It is throwing errors in the console every time I try to open it.
Is there some way to edit a template without the Designer trying to execute it?
I could probably fix the problem if I could open it.
Here are the errors:
Exception in thread "AWT-EventQueue-0" java.lang.ArithmeticException: / by zero
	at com.inductiveautomation.factorypmi.application.components.chart.easychart.ConstantPenDatasource.createTimeColumn(ConstantPenDatasource.java:124)
	at com.inductiveautomation.factorypmi.application.components.chart.easychart.ConstantPenDatasource.updateData(ConstantPenDatasource.java:108)
	at com.inductiveautomation.factorypmi.application.components.chart.easychart.ConstantPenDatasource.startup(ConstantPenDatasource.java:80)
	at com.inductiveautomation.factorypmi.application.components.PMIEasyChart$EasyChart.startup(PMIEasyChart.java:2220)
	at com.inductiveautomation.factorypmi.application.components.PMIEasyChart$EasyChart.createChartImpl(PMIEasyChart.java:2763)
	at com.inductiveautomation.factorypmi.application.components.chart.PMILineChartPanel.createChart(PMILineChartPanel.java:135)
	at com.inductiveautomation.factorypmi.application.components.PMIEasyChart$ChartUpdater.run(PMIEasyChart.java:703)
	at com.inductiveautomation.ignition.client.util.EDTUtil$ProcessQueue.run(EDTUtil.java:126)
	at java.base/java.security.AccessController.doPrivileged(Unknown Source)
	at com.inductiveautomation.factorypmi.application.components.PMIEasyChart$EasyChart.setQueriesEnabled(PMIEasyChart.java:2953)
	at com.inductiveautomation.factorypmi.application.components.PMIEasyChart.startupComponent(PMIEasyChart.java:3269)
	at com.inductiveautomation.factorypmi.application.components.util.ComponentVisitor$StartupVisitor.visit(ComponentVisitor.java:344)
	at com.inductiveautomation.factorypmi.application.components.util.ComponentVisitor.walk(ComponentVisitor.java:95)
	at com.inductiveautomation.factorypmi.application.components.template.VisionTemplate.startup(VisionTemplate.java:182)
	at com.inductiveautomation.factorypmi.designer.workspace.WindowWorkspace.openTemplate(WindowWorkspace.java:2208)
	at com.inductiveautomation.factorypmi.designer.workspace.WindowWorkspace.openTemplate(WindowWorkspace.java:2178)
	at com.inductiveautomation.factorypmi.designer.workspace.WindowWorkspace.openTemplate(WindowWorkspace.java:2236)
	at com.inductiveautomation.factorypmi.designer.beaninfo.TemplateHolderBeanInfo$PopupInitializer$1.actionPerformed(TemplateHolderBeanInfo.java:212)
	at java.desktop/javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
	at java.desktop/javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
	at java.desktop/javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
	at java.desktop/javax.swing.DefaultButtonModel.setPressed(Unknown Source)
	at java.desktop/javax.swing.AbstractButton.doClick(Unknown Source)
	at java.desktop/javax.swing.plaf.basic.BasicMenuItemUI.doClick(Unknown Source)
	at java.desktop/javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(Unknown Source)
	at java.desktop/java.awt.AWTEventMulticaster.mouseReleased(Unknown Source)
	at java.desktop/java.awt.EventQueue$5.run(Unknown Source)
	at com.inductiveautomation.factorypmi.designer.beaninfo.TemplateHolderBeanInfo$OpenTemplateForDesign.onDoubleClick(TemplateHolderBeanInfo.java:194)
	at com.inductiveautomation.factorypmi.designer.workspace.WindowWorkspace.handleDoubleClick(WindowWorkspace.java:976)
	at com.inductiveautomation.ignition.designer.designable.tools.SelectionTool.onDoubleClick(SelectionTool.java:553)
	at com.inductiveautomation.ignition.designer.designable.DesignPanel$ToolMouseListener.onClick(DesignPanel.java:975)
	at com.inductiveautomation.ignition.client.util.gui.CommonMouseAdapter.mouseReleased(CommonMouseAdapter.java:72)
09:24:41.851 [AWT-EventQueue-0] INFO tags.subscriptions -- Changing connected quality to 'Good'
09:24:41.884 [DesignerExecEngine-2] WARN tags.subscriptions -- Subscription crc mismatch, will resubscribe.
09:24:46.874 [AWT-EventQueue-0] INFO tags.subscriptions -- Changing connected quality to 'Bad_GatewayCommOff'
I've tried a few things:
Opening the template with Gateway comms turned off.
Exporting the template to import and open in a separate project.
I don't think so. Just restore the template backup you made before the changes.
Shift-Right-Click on the template in the designer tree, select Copy XML. Paste in to a text editor and go hunting.
When you think you have it fixed, copy back to the clipboard, then Shift-Right-Click on the template in the designer, and pick Paste XML.
(Good luck. The XML format is quite cryptic.)
Thanks Phil.
I might be able to get it working there, but probably will waste more time than needed. (Its almost 3000 lines of XML.) I guess I'll rebuild it from my starting point. But this might be useful in the future.
-Caleb
