I have an issue with trying to add template parameter. Anytime I add a new parameter to an existing or new template I get the following error:
java.lang.NullPointerException
at com.inductiveautomation.factorypmi.designer.property.customizers.DynamicPropertyProviderCustomizer.getRemovedPropertySet(DynamicPropertyProviderCustomizer.java:208)
at com.inductiveautomation.factorypmi.designer.property.customizers.DynamicPropertyProviderCustomizer.tryCommit(DynamicPropertyProviderCustomizer.java:372)
at com.inductiveautomation.factorypmi.designer.property.CustomizerDialog.actionPerformed(CustomizerDialog.java:136)
at javax.swing.AbstractButton.fireActionPerformed(Unknown Source)
at javax.swing.AbstractButton$Handler.actionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.fireActionPerformed(Unknown Source)
at javax.swing.DefaultButtonModel.setPressed(Unknown Source)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(Unknown Source)
at java.awt.Component.processMouseEvent(Unknown Source)
at javax.swing.JComponent.processMouseEvent(Unknown Source)
at java.awt.Component.processEvent(Unknown Source)
at java.awt.Container.processEvent(Unknown Source)
at java.awt.Component.dispatchEventImpl(Unknown Source)
at java.awt.Container.dispatchEventImpl(Unknown Source)
at java.awt.Component.dispatchEvent(Unknown Source)
at java.awt.LightweightDispatcher.retargetMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.processMouseEvent(Unknown Source)
at java.awt.LightweightDispatcher.dispatchEvent(Unknown Source)
Ignition v7.6.0 (b1875)
Java: Sun Microsystems Inc. 1.6.0_30
I don’t get it when adding custom properties to objects however.
