Hello,
I was just working on my vision project and adding a template to a few of the windows. All of a sudden when I reopen the windows the contents of the template disappeared and when accessing the template itself I get a “Template doesn’t exist” error.
com.inductiveautomation.factorypmi.application.model.TemplateNotFoundException: TemplateInfo for template Status_Arrow was null.
at com.inductiveautomation.factorypmi.application.model.TemplateManager.getTemplateInfo(TemplateManager.java:304)
at com.inductiveautomation.factorypmi.application.model.TemplateManager.getTemplateInstance(TemplateManager.java:153)
at com.inductiveautomation.factorypmi.designer.workspace.WindowWorkspace.openTemplate(WindowWorkspace.java:1872)
at com.inductiveautomation.factorypmi.designer.model.navtree.TemplateNode.open(TemplateNode.java:128)
at com.inductiveautomation.ignition.designer.navtree.model.AbstractResourceNavTreeNode.onDoubleClick(AbstractResourceNavTreeNode.java:266)
at com.inductiveautomation.ignition.designer.navtree.NavTreePanel$MouseListener.lambda$mousePressed$0(NavTreePanel.java:656)
Ignition v8.0.5 (b2019101516)
Java: Azul Systems, Inc. 11.0.4
I know I can restore an older backup and export the template and import it back but I’d like to know why this happened in the first place and if it’s a possible bug it can be fixed for future versions.
Thanks.
