I have Template repeater configured with below settings, it looks alright in designer & preview mode but it does not appears as expected in vision client.
I need rows in template repeater set to be Top to Bottom & left to right but it does not appear as expected in vision client and also template repeater size looks completely distorted in client.
FYI - I am using Ignition 7.9
- Repeat Behaviour - Dataset
- Dataset - 163x22
- Layout Style - Bestfit
- Flow direction - Verticle
- Flow alignment - Left/Top
Can someone help me here, whats needs to be done.
Thank you in advance.
Try changing the layout setting. I can’t remember the settings and the user manual doesn’t tell me (@Paul.Scott).
Can you copy in a screenshot of both in designer view and in the client?
What resolution is your client? It looks a lot smaller than the designer
I can’t really tell if this will help or not, but I used to always have to remind folks about the Enable Layout setting of a given template:
If you find that things aren’t aligning to expectations regarding your layout configurations, always check this setting on the templates you’re using. Vision Templates - Ignition User Manual 8.1 - Ignition Documentation
Thank you Kevin!
I will try your suggestions.
