Hi!
I’m trying to make a window with some elements scrolling constantly. In this way, I found that if I use the template repeater with this configuration:
It make a continuous vertical scroll. But if I make the same configuration changing only the flow direction:
It doesn’t move! And I need it to scroll in the horizontal way. Does anyone know why?
Is there any other parameter that I have to change?
Should I assume that as impossible?
I’ve never used that, so I don’t know if this will be helpful or not.
What happens if you change the Template Dataset from 5R x 2C to 2R x 5C? Is that possible?
It refers to the parameters of the different templates. I mean, in this case, I inserted 5 instances of the templates with 2 parameters each one (5R x 2C).
So this modification doesn’t affects. But thanks!
