Hi everybody,
I create a screen with Template Repeater element. I configure it as Dataset and throw all elements (from 1 to 30) on a row. (Note that the elements are Template elements.)
The first template (1) throw incorrect values
From 2 and go on templates are shown all correctly.
But, the last element (30) doesn’t appear.
Dataset rows are numbered from zero. So your rows would be 0-29, not 1-30. If you are misusing the index parameter, that would explain what you are seeing.
Hi pturmel,
Thanks for your response. You’re right.
I established the index parameter name, but I only could establish directly the template parameter text.
My solution at the moment is:
On the template parameter put the same item_name that I’ve on the results of SQL query of Template Repeater → Template Parameters.
