Trying to set what templates that’s enabled when a window is opened. Using custom properties and the property changed event and it all seems to work fine WHEN the window has been opened, just not the first time. After a little debugging I figured that .getLoadedTemplates() returns 0, even when filtering on the componentRunning property which seems to be the last property that change on the repeater when the window opens.
Any suggestions?
