I want to manipulate the dataset parameter of a template repeater based on a value.
I have only one template parameter - “Rack_Num”. And i would like to create a column in the dataset with 13 rows.
eg : if VALUE = 1: Rack_Num column to be created in dataset with values 1-13.
if VALUE = 2: Rack_Num column to be created in dataset with values 14-26.
if VALUE = 3: Rack_Num column to be created in dataset with values 27-39.
if VALUE = 4: Rack_Num column to be created in dataset with values 40-52.
if VALUE = 5: Rack_Num column to be created in dataset with values 53-65.
Currently i have just entered values by hand but the requirement is to dynamize the columns based on a value. Just added a screenshot for dataset as it is being used now.
I am using template repeater for the first time and cant get my head around this problem.
Can anyone please help?
