I am using a template and template repeater.
For simplicity, I’ll call the template “circle”
On the “circle” template I have a customer property called “status”.
If I use the template repeater, have it repeat 10 instances of the template “circle” I also have 10 instances of the “circle.status” custom property.
Is it possible, through scripting to manipulate all 10 instances of “circle.status” based on a mouse click on a any one of the templates in the template repeater? Code example:
# In the Event Handler: mouse/mouseReleased the following script would be called
if circle #1.status == 1:
circle #2.status = 0
circle #3.status = 0
circle #4.status = 0
circle #5.status = 0
circle #6.status = 0
circle #7.status = 0
circle #8.status = 0
circle #9.status = 0
circle #10.status = 0
Because the script is embedded on the template itself, it won’t have any reference to the other templates in the repeater correct? So I’m not sure I can do something like this at the template level…probably something at the template repeater level?
