I am having trouble trying to access via looping the dataset of my template repeater to hide or animate some components based on the index value and the custom properties created on the component template
Please explain what you are trying to accomplish. Mostly, scripting is used to construct the template parameters dataset to control what is loaded and what those templates get as parameter values. The index parameter name is simply not used when repeat behavior == “Dataset”.
