After exporting a project from a testing server and then importing it into our live server the Gateway Timer scripts did not run. They were functioning fine in test server. I have not touched them just in case someone from IA would like to look at the system.
You can call our tech support so we can look at it.
Got it fixed. Here is what I think may have happened after working through it with Tech-Support.
I had the project on both servers, same name. Through time the testing server project got set to “Auto” and the live server was set to Manual. When the project was then updated on the live server things got out of wack.
Not sure it that could have caused it. The fix was to delete the project from the live server completely and not just over right it. Then do a fresh import.
Hope this may help someone else someday.
