Text Field binded to table.props.data Next and Back buttons
Hi!
In ignition perspective I have a text field binded to a data from a table
.../TablaInventario.props.data[0]['Clase equipo']
so it shows the data from column "Clase equipo" in row 0
I want to add a "next" button so this text field change to next row and show its data
.../TablaInventario.props.data[1]['Clase equipo']
also a back button
For now I added expression to the text filed:
try({../TablaInventario.props.data}[{../custom.currentIndex}]['Clase equipo'], "")
And this to the next button:
def runAction(self, event):
    totalRows = len(self.getSibling("TablaInventario").props.data)
    if self.view.custom.currentIndex < totalRows - 1:
        self.view.custom.currentIndex += 1
and back button:
   if self.view.custom.currentIndex > 0:
        self.view.custom.currentIndex -= 1
  1. Don't offer controls options that don't work. That means disable the < if you are at the first row and disable the > if you are at the last.
  2. On the Text Field component create custom.selectedRow. Set it to 0.
  3. On < add an expression binding to enabled.
    {../TextField.custom.selectedRow} > 0
  4. On > add an expression binding to enabled.
    {../TextField.custom.selectedRow} < len({..../TablaInventario.props.data}) - 1
  5. On < add an onActionPerformed script:
    self.getSibling("TextField").custom.selectedRow -= 1
  6. On > add an onActionPerformed script:
    self.getSibling("TextField").custom.selectedRow += 1
  7. On the Text Field component props.text add an expression binding:
    {..../TablaInventario.props.data}[{this.custom.selectedRow}]['Clase equipo']
Table row to text field
Was this value changing? It would need to be bound to the table's selected row.
Expressions are better than scripts.
Your solution doesn't seem to disable the buttons. Again, " Don't offer controls options that don't work.".
Yes I changed that expression {../TextField.custom.selectedRow} to {parent.custom.selectedRow}
I’m making it common across all the text fields I’m using.
my solution doesn´t disable the buttons.
right, I just deleted the post, thanks.
