Text Field, Check box in Flex Container Padding Issue
In this image, there are two numeric fields, two text fields, two check boxes and one button.
They live inside a flex container (1).
The flex container lives inside an embedded view (2) in another flex container (3).
I added padding to flex (1). As you can see the numeric fields and button responded to the padding but seemingly not the others.
Edit: the same thing happens with adding a bottom margin to flex (1).
Why is this? Is there a way to force them into submission?
Post the flex container here as formatted code so we can have a look. If you're referencing any style classes then post those too.
Top level of the flex:
{"type":"view","payload":{"view":{"path":"Page/ctr/SourceBay_Emb04","width":750.0,"height":82.0,"params":{}}}}
Root:
    "type": "ia.container.flex",
    "version": 0,
    "props": {
      "direction": "column",
      "style": {
        "margin-bottom": "2px",
        "margin-top": "2px"
    "meta": {
      "name": "root"
    "position": {},
    "custom": {
      "sb_lbl_bgc": "#A5DAFD",
      "font": "calc(0.25vw + 0.5em)",
      "font_sm": "calc(0.25vw + 0.4em)",
      "font_smaller": "calc(0.25vw + 0.3em)"
    "children": [
        "version": 0,
        "props": {
          "justify": "space-evenly",
          "style": {
            "overflow": "visible",
            "padding-bottom": "0px",
            "margin-bottom": "5px"
        "meta": {
          "name": "Flex_Top"
        "position": {
          "basis": "27px"
        "custom": {},
        "children": [
            "type": "ia.display.label",
            "version": 0,
            "props": {
              "text": "CZ01",
              "style": {
                "margin-right": "2px"
            "meta": {
              "name": "lbl_Zone"
            "position": {
              "basis": "35px"
            "custom": {},
            "propConfig": {
              "props.style.font-size": {
                "binding": {
                  "type": "property",
                  "config": {
                    "path": "/root.custom.font"
            "version": 0,
            "props": {
              "text": "16-1",
              "style": {
                "text-align": "center"
            "meta": {
              "name": "lbl_SB1"
            "position": {
              "basis": "35px"
            "custom": {},
            "propConfig": {
              "props.style.background-color": {
                "binding": {
                  "config": {
                    "path": "/root.custom.sb_lbl_bgc"
                  "type": "property"
                "binding": {
                  "type": "property",
                  "config": {
                    "path": "/root.custom.font_sm"
            "version": 0,
            "props": {
              "text": "SnSn+",
              "style": {
                "font-weight": "bold",
            "meta": {
              "name": "lbl_SB1_Mat"
            "position": {
              "basis": "32px"
            "custom": {},
            "propConfig": {
                "binding": {
                  "type": "property",
                  "config": {
                    "path": "/root.custom.font_smaller"
            "type": "ia.input.button",
            "version": 0,
            "props": {
              "text": "Action",
              "primary": false,
              "style": {
                "fontFamily": "Arial",
                "fontWeight": "normal",
            "meta": {
              "name": "btn_SB1_Action"
            "position": {
              "basis": "44px"
            "custom": {},
            "propConfig": {
                "binding": {
                  "type": "property",
                  "config": {
            "type": "ia.input.numeric-entry-field",
            "version": 0,
            "props": {
              "format": "none",
              "spinner": {
                "enabled": false
              "style": {
            "meta": {
              "name": "num_SB1_Lid"
            "position": {
              "basis": "55px"
            "custom": {},
            "propConfig": {
                "binding": {
                  "type": "property",
                  "config": {
            "version": 0,
            "props": {
              "format": "none",
              "spinner": {
                "enabled": false
              "style": {
            "meta": {
              "name": "num_SB1_MM1"
            "position": {
              "basis": "55px"
            "custom": {},
            "propConfig": {
                "binding": {
                  "type": "property",
                  "config": {
            "version": 0,
            "props": {
              "format": "none",
              "spinner": {
                "enabled": false
              "style": {
            "meta": {
              "name": "num_SB1_Percent1"
            "position": {
              "basis": "55px"
            "custom": {},
            "propConfig": {
                "binding": {
                  "type": "property",
                  "config": {
            "version": 0,
            "props": {
              "format": "none",
              "spinner": {
                "enabled": false
              "style": {
            "meta": {
              "name": "num_SB1_MM2"
            "position": {
              "basis": "55px"
            "custom": {},
            "propConfig": {
                "binding": {
                  "type": "property",
                  "config": {
            "version": 0,
            "props": {
              "format": "none",
              "spinner": {
                "enabled": false
              "style": {
            "meta": {
              "name": "num_SB1_Percent2"
            "position": {
              "basis": "45px"
            "custom": {},
            "propConfig": {
                "binding": {
                  "type": "property",
                  "config": {
            "type": "ia.input.text-area",
            "version": 0,
            "props": {
              "spellcheck": false,
              "wrap": "off",
              "style": {
            "meta": {
              "name": "txt_SB1_Used"
            "position": {
              "basis": "55px"
            "custom": {},
            "propConfig": {
                "binding": {
                  "type": "property",
                  "config": {
            "version": 0,
            "props": {
              "wrap": "off"
            "meta": {
              "name": "txt_SB1_Notes"
            "position": {
              "grow": 1,
              "basis": "100px"
            "custom": {},
            "propConfig": {
                "binding": {
                  "type": "property",
                  "config": {
            "type": "ia.input.checkbox",
            "version": 0,
            "props": {
              "text": ""
            "meta": {
              "name": "chk_SB1_Trim"
            "position": {
              "basis": "30px"
            "custom": {}
            "version": 0,
            "props": {
              "text": ""
            "meta": {
              "name": "chk_Major"
            "position": {
              "basis": "30px"
            "custom": {}
            "version": 0,
            "props": {
              "text": "Reset",
              "primary": false,
              "style": {
                "font-weight": "normal",
            "meta": {
              "name": "btn_Reset"
            "position": {
              "basis": "44px"
            "custom": {},
            "propConfig": {
                "binding": {
                  "type": "property",
                  "config": {
        "version": 0,
        "props": {
          "style": {
        "meta": {
          "name": "Flex_Top_0"
        "position": {
          "basis": "27px"
        "custom": {},
        "children": [
            "version": 0,
            "props": {
              "style": {
                "font-size": "calc(0.25vw + 0.5em)",
            "meta": {
              "name": "lbl_Misc01"
            "position": {
              "basis": "35px"
            "custom": {}
            "version": 0,
            "props": {
              "text": "16-1",
              "style": {
                "font-size": "calc(0.25vw + 0.4em)",
            "meta": {
              "name": "lbl_SB1"
            "position": {
              "basis": "35px"
            "custom": {},
            "propConfig": {
                "binding": {
                  "config": {
                  "type": "property"
            "version": 0,
            "props": {
              "text": "SnSn+",
              "style": {
                "font-size": "calc(0.25vw + 0.35em)",
            "meta": {
            "position": {
              "basis": "32px"
            "custom": {}
            "version": 0,
            "props": {
              "text": "Action",
              "primary": false,
              "style": {
                "font-size": "calc(0.25vw + 0.42em)",
            "meta": {
            "position": {
              "basis": "44px"
            "custom": {}
            "version": 0,
            "props": {
              "style": {
            "meta": {
            "position": {
              "basis": "55px"
            "custom": {}
            "version": 0,
            "props": {
              "style": {
            "meta": {
            "position": {
              "basis": "55px"
            "custom": {}
            "version": 0,
            "props": {
              "style": {
            "meta": {
            "position": {
              "basis": "55px"
            "custom": {}
            "version": 0,
            "props": {
              "style": {
            "meta": {
            "position": {
              "basis": "55px"
            "custom": {}
            "version": 0,
            "props": {
              "style": {
            "meta": {
            "position": {
              "basis": "45px"
            "custom": {}
            "version": 0,
            "props": {
              "wrap": "off",
              "style": {
            "meta": {
            "position": {
              "basis": "55px"
            "custom": {}
            "version": 0,
            "props": {
              "wrap": "off",
              "style": {
            "meta": {
            "position": {
              "grow": 1,
              "basis": "100px"
            "custom": {}
            "version": 0,
            "props": {
              "text": ""
            "meta": {
            "position": {
              "basis": "30px"
            "custom": {}
            "version": 0,
            "props": {
              "text": ""
            "meta": {
              "name": "chk_Major"
            "position": {
              "basis": "30px"
            "custom": {}
            "version": 0,
            "props": {
              "text": "Reset",
              "primary": false,
              "style": {
            "meta": {
              "name": "btn_Reset"
            "position": {
              "basis": "44px"
            "custom": {}
        "version": 0,
        "props": {
          "style": {
        "meta": {
          "name": "Flex_Top_1"
        "position": {
          "basis": "27px"
        "custom": {},
        "children": [
            "version": 0,
            "props": {
              "style": {
            "meta": {
            "position": {
              "basis": "35px"
            "custom": {}
            "version": 0,
            "props": {
              "text": "16-1",
              "style": {
            "meta": {
              "name": "lbl_SB1"
            "position": {
              "basis": "35px"
            "custom": {},
            "propConfig": {
                "binding": {
                  "config": {
                  "type": "property"
            "version": 0,
            "props": {
              "text": "SnSn+",
              "style": {
            "meta": {
            "position": {
              "basis": "32px"
            "custom": {}
            "version": 0,
            "props": {
              "text": "Action",
              "primary": false,
              "style": {
            "meta": {
            "position": {
              "basis": "44px"
            "custom": {}
            "version": 0,
            "props": {
              "style": {
            "meta": {
            "position": {
              "basis": "55px"
            "custom": {}
            "version": 0,
            "props": {
              "style": {
            "meta": {
            "position": {
              "basis": "55px"
            "custom": {}
            "version": 0,
            "props": {
              "style": {
            "meta": {
            "position": {
              "basis": "55px"
            "custom": {}
            "version": 0,
            "props": {
              "style": {
            "meta": {
            "position": {
              "basis": "55px"
            "custom": {}
            "version": 0,
            "props": {
              "style": {
            "meta": {
            "position": {
              "basis": "45px"
            "custom": {}
            "version": 0,
            "props": {
              "wrap": "off",
              "style": {
            "meta": {
            "position": {
              "basis": "55px"
            "custom": {}
            "version": 0,
            "props": {
              "wrap": "off",
              "style": {
            "meta": {
            "position": {
              "grow": 1,
              "basis": "100px"
            "custom": {}
            "version": 0,
            "props": {
              "text": ""
            "meta": {
            "position": {
              "basis": "30px"
            "custom": {}
            "version": 0,
            "props": {
              "text": ""
            "meta": {
              "name": "chk_Major"
            "position": {
              "basis": "30px"
            "custom": {}
            "version": 0,
            "props": {
              "text": "Reset",
              "primary": false,
              "style": {
            "meta": {
              "name": "btn_Reset"
            "position": {
              "basis": "44px"
            "custom": {}
Forgot to mention that the browser is set to very large font and the OS zoom is 125%.
I've just lost interest! (But does it work on normal settings?)
Um... yes...
Deja vu?
Oh god! scaling 2.0 for the designer is killing me! I can't work LOL. I don't think this is going be the solution for fixing my user's issue with zoom and large font in a browser. But, thanks for the tip IF my eyesight gets real bad!
I feel your pain; that scaling option breaks way more than its worth, and as a developer, when I write code to override or mitigate the effects of that option, it bothers me that my app is now more bloated and less efficient than it could have otherwise been if microsoft had just left the scaling options up to me.
I imagine that it would help if it were labeled as an accessibility feature like spoken text or on screen keyboard, so the user would have a sense that that an abnormal configuration is being selected. Instead, it's packaged under the normal display set up settings, and often times, I encounter things like this:
Uggh!
