From my understanding setting the ‘text’ property of a text field component to ‘None’ or a blank string ‘‘ should result in the text field displaying the placeholder property text.
self.props.text = None
This code results in the text value being set to the value “Null” as seen below. I have also included another instance of the text field below it displaying how the placeholder text should be appearing.
Am I doing something wrong?
I’d say that’s how it should work for nulls as well, but currently “empty” (as mentioned by the user manual) means an empty string
I get the same result if I use the following
self.props.text = ‘‘
or
self.props.text = ““
Setting it to None or an empty string both result in a ‘Null’ text value rather than an empty text box
can you show a screenshot of the component text prop?
this works for me (i.e. self.props.text = ''):
This is in a message handler that is triggered upon saving the input value.
Copy this component JSON into your View and see if it works for you. it’s just the JSON for a simple text field component. Toggle the “key” bool and will send a p.msg “bob” with a handler that sets the text to an empty string and then the placeholder appears
"type": "ia.input.text-field",
"version": 0,
"props": {
"text": "You'll never catch me!",
"placeholder": "Peek-a-boo!"
"meta": {
"name": "TextField"
"position": {
"basis": "32px"
"custom": {
"key": false
"propConfig": {
"custom.key": {
"onChange": {
"script": "\tsystem.perspective.sendMessage('bob')",
"enabled": null
"scripts": {
"customMethods": [],
"messageHandlers": [
"messageType": "bob",
"script": "\tself.props.text = ''",
"sessionScope": false,
"pageScope": true,
"viewScope": false
"extensionFunctions": null
Edit: what component is that message handler code defined on?
Thanks for your help, I have resolved it. There was a change script I wasn’t aware of that was setting the value to ‘None’ in the case that it was set to an empty string which was causing the issue.
Setting self.props.text = ‘‘ will result in an empty box, self.props.text = None will result in the text ‘Null’
Thanks again
