Text field for popup "Info" screens?
I'm not finding where to create a text field for creating popup "Info" windows in Vision. It's display only, and needs to be big enough for a couple of paragraphs of information. Can you point me in the right direction, please?
The text area component?
https://docs.inductiveautomation.com/display/DOC81/Vision+-+Text+Area
Ok... I was hesitant to use this because it is labeled as an input text field. But I see that there is an "editable" property that can be turned off. I'll play around with it and see how it works.
Thanks!
The markdown component is also good, you get some more advanced syntax options for styling.
Edit: Perspective advice in a Vision thread.
I would normally use a label component for this. Html can be used to customize the info appearance.
