Text inside of template scaling
Hi! Is there a way to scale text inside a template so that it retains original font size, even if the template is resized when used? For example, I have a template that I would like to use as a slightly different size, but this also scales the text, which I do not want in this case.
It is simple enough to make a separate template if I need to, just not sure if I'm missing something obvious
Use anchored layout within the template.
