That slows the process of screens?
every time you change from one screen to another it takes to change
why is this happening?
if my computer has Windows XP and has 2GB of RAM
Soo, When you have a project w/ multiple windows, Switching from one window to another takes how long?
It takes between 4 to 5 seconds
Does it do this every time or only the first time you switch w/ that application open?
is only when you start the application
but who does?
I think this is normal…
Do you have large images? If so, you might be able to resize them. What about slow SQL queries?
The window downloads from the gateway across the network on first load, then is cached upon subsequent loads.
[quote=“nathan”]Do you have large images? If so, you might be able to resize them. What about slow SQL queries?
The window downloads from the gateway across the network on first load, then is cached upon subsequent loads.[/quote]
I do not think the images are larger because the 500kb.
which is the size that you recommend on images?
That is fairly large. Especially if they have to be resized dynamically to fit your screen. How are they encoded?
