The connection to the gateway is not available
WhenI am opening designer I am getting the error mentioned in the log.
The gateway is although working fine.
How to fixt his?
logs
Blockquote
com.inductiveautomation.ignition.client.gateway_interface.GatewayException: The connection to the gateway is not available.
at com.inductiveautomation.ignition.designer.gateway.PriviledgedDesignerTask$GatewayMessageTask.canRun(PriviledgedDesignerTask.java:450)
at com.inductiveautomation.ignition.designer.gateway.PriviledgedDesignerTask.run(PriviledgedDesignerTask.java:161)
at com.inductiveautomation.ignition.designer.gateway.PriviledgedDesignerTask.runTask(PriviledgedDesignerTask.java:146)
at com.inductiveautomation.ignition.designer.gateway.DTGatewayInterface.run(DTGatewayInterface.java:63)
at com.inductiveautomation.ignition.designer.gateway.DTGatewayInterface.run(DTGatewayInterface.java:58)
at com.inductiveautomation.ignition.designer.gateway.DTGatewayInterface.getDatasources(DTGatewayInterface.java:114)
at com.inductiveautomation.ignition.designer.gui.DatasourceComboBox.getOptions(DatasourceComboBox.java:38)
at com.inductiveautomation.ignition.client.util.gui.AbstractProfileOptionDropdown.refresh(AbstractProfileOptionDropdown.java:143)
at com.inductiveautomation.ignition.client.util.gui.AbstractProfileOptionDropdown.(AbstractProfileOptionDropdown.java:72)
at com.inductiveautomation.ignition.designer.gui.DatasourceComboBox.(DatasourceComboBox.java:30)
at com.inductiveautomation.ignition.designer.gui.DatasourceComboBox.(DatasourceComboBox.java:26)
at com.inductiveautomation.factorysql.designer.model.controls.ConfigDatasourceComboBox.(ConfigDatasourceComboBox.java:22)
at com.inductiveautomation.factorysql.designer.panels.MultiselectActionPanel.initComponents(MultiselectActionPanel.java:74)
at com.inductiveautomation.factorysql.designer.panels.MultiselectActionPanel.(MultiselectActionPanel.java:37)
at java.base/jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
at java.base/jdk.internal.reflect.NativeConstructorAccessorImpl.newInstance(Unknown Source)
at java.base/jdk.internal.reflect.DelegatingConstructorAccessorImpl.newInstance(Unknown Source)
at java.base/java.lang.reflect.Constructor.newInstance(Unknown Source)
at com.inductiveautomation.factorysql.designer.model.TabDefinition.instantiateComponent(TabDefinition.java:70)
at com.inductiveautomation.factorysql.designer.views.WorkspaceView.loadWorkspace(WorkspaceView.java:117)
at com.inductiveautomation.factorysql.designer.views.WorkspaceView.updateWorkspace(WorkspaceView.java:105)
at com.inductiveautomation.factorysql.designer.GroupResourceWorkspace.(GroupResourceWorkspace.java:130)
at com.inductiveautomation.factorysql.designer.FSQLDesignerModuleHook.startup(FSQLDesignerModuleHook.java:220)
at com.inductiveautomation.ignition.designer.IgnitionDesigner$LoadedModule.startup(IgnitionDesigner.java:1934)
at com.inductiveautomation.ignition.designer.IgnitionDesigner.startupModule(IgnitionDesigner.java:1174)
at com.inductiveautomation.ignition.designer.IgnitionDesigner.lambda$loadProject$9(IgnitionDesigner.java:995)
at java.base/java.util.stream.ForEachOps$ForEachOp$OfRef.accept(Unknown Source)
at java.base/java.util.stream.ReferencePipeline$2$1.accept(Unknown Source)
at java.base/java.util.ArrayList$ArrayListSpliterator.forEachRemaining(Unknown Source)
at java.base/java.util.stream.AbstractPipeline.copyInto(Unknown Source)
at java.base/java.util.stream.AbstractPipeline.wrapAndCopyInto(Unknown Source)
at java.base/java.util.stream.ForEachOps$ForEachOp.evaluateSequential(Unknown Source)
at java.base/java.util.stream.ForEachOps$ForEachOp$OfRef.evaluateSequential(Unknown Source)
at java.base/java.util.stream.AbstractPipeline.evaluate(Unknown Source)
at java.base/java.util.stream.ReferencePipeline.forEach(Unknown Source)
at com.inductiveautomation.ignition.designer.IgnitionDesigner.loadProject(IgnitionDesigner.java:994)
at com.inductiveautomation.ignition.designer.IgnitionDesigner$StartupProjectDialogHandler.lambda$new$2(IgnitionDesigner.java:1998)
Can you access the gateway via the webpage?
