The intent named has been registered multiple times
Hello!
I'm getting this warning on the logs of the Ignition Gateway while I'm unable to get Tag History Sync Services up from an Ignition Edge Gateway although, I got the Sync ID at the Edge side.
The error in the standard gateway is as follows:
The intent named 'tagsubupd_tagsubupd_<Remote Gateway Name>-vadapter' has been registered multiple times.
Service security is set up correctly to allow Query and Storage by default.
Looking the logs at the Edge side I got a warning:
Remote historian sink isn't accepting data at this time. Likely that the remote gateway is unavailable.
The gateway network is running fine with no interruptions and it is possible to look realtime tag information when browsed remotely from the standard Ignition gateway.
Any idea will be much appreciated
I am getting the same error now...Have you found anything?
Hi Hans, I found this happen when the network has a high latency. The data is pushed to the remote Ignition Gateway, but not as fast as expected.
