Hello,I'm having a problem.I can't open session.custom in Perspective Property Editor.I try four device,all of them have this problem.I'm want to edit a binding right now.Please help me to solve it.
Welcome to the forum.
Make sure that the Property Editor's filter is empty.
Note that the image in your post shows "PARAMS", The session does not take parameters so that is looking at some other component.
Thank you.
I just check my editor,the Property Editor's filter is empty.
There's only session props and session costum a few hours ago.
But I don't know what config is wrong ,there's SESSION PROPS,SESSION POSITION,CUSTOM and META now.
Do you know which config is about this editor?
Post a picture showing both the Project Browser and the Perspective Property Editor so we can see what is going on. Make sure we can see the filters and what component is selected.
I know what you means.
I closed all views in perspective.
You can see in my pictures above,at the bottom of the pictures have nothing but the session.
Your images do not show the Project Browser so I cannot see what is selected.
The error in the binding of a variable in session.custom, as seen through the output console, caused the editor to fail to load. The final solution involved exporting session-props using the designer, modifying the props.json file locally by removing (or correcting) the erroneous script, and then importing it back into the designer. This resolved the issue, and after re-adding the content in session.custom and ensuring that the binding was error-free, the functionality was restored to normal.
