Tag value is null, tag type is Float, But in Table show value is 0.
I want show null or empty.
How to do that?
Pease help me, Thanks a lot!
Is the table using a history binding? If so, please show the binding.
I don't know enough to answer for sure but a simple check would be to change the binding Value Format from Dataset to Document. You can then inspect the returned values in the PROPS.data of the table component. If you see nulls in there then the table component is converting them to '0'. If not then the problem is probably with the history interpolation (which I have found to be almost useless).
A quick test with the default table data shows that entering 'null' in the population column results in an empty cell in auto or numeric rendering. Rendering as a string shows 'null'.
