The tag does not support writing
I keep getting an error when writing to a tag parameter. It says The Tag does not support writing.
Is there any way to fix this
What kind of tag is it? Is it set to read-only mode, or read/write? Got a screenshot?
And which parameter are you writing to? Not all attributes can be directly written.
I have attached a snippet of the parameter I want to change.
UDT parameters need to be changed using the system.tag.editTag function: https://docs.inductiveautomation.com/display/DOC79/system.tag.editTag
That is what I’m using. I have attached the script below.
You're using system.tag.write, not system.tag.editTag
My bad thanks for pointing it out :slight_smile:
