Hi Team I am creating a testing environment with docker compose up -d
This is my docker-compose.yml . A minutes ago was working . I tried to update the last version of the image and failed and I changed the version of the image to 8.1.2 and
docker compose down -v
and
services:
frontend:
image: inductiveautomation/ignition:8.1.2
hostname: frontend
ports:
- 9088:8088
volumes:
- frontend-data:/usr/local/bin/ignition/data
networks:
- frontend
environment:
- IGNITION_EDITION=standard
- GATEWAY_ADMIN_PASSWORD=password
- ACCEPT_IGNITION_EULA=Y
command: >
-n frontend-gateway
backend:
hostname: backend
ports:
- 9089:8088
volumes:
- backend-data:/usr/local/bin/ignition/data
networks:
- frontend
- backend
environment:
command: >
-n backend-gateway
db:
image: mariadb:10.10.2
ports:
- 3306:3306
volumes:
- db-data:/var/lib/mysql
networks:
backend:
aliases:
- main-db
environment:
- MARIADB_ROOT_PASSWORD=ignition
- MARIADB_DATABASE=ignition
- MARIADB_USER=ignition
- MARIADB_PASSWORD=ignition
smtp:
image: dockage/mailcatcher:0.8.2
ports:
- 1080:1080
- 1025:1025
networks:
backend:
aliases:
- mail-server
networks:
frontend:
backend:
volumes:
frontend-data:
backend-data:
db-data:
But now show this
The environment config its not working
