I currently have several windows showing that someone else is editing them. Looking at the “Concurrent Users” box, it shows that myself, and two others are editing various things.
The problem is, I’m listed as the one editing everything, from the same IP, same username. Nothing seems to make the status go away.
Is there any solution?
I get that same message from time to time. Just disregard, open and edit anyway. It should then go away after you open and save.
Oh, it works, it is just annoying, especially since it is on probably 30 displays in this project. Restarting the gateway didn’t clear it either, and I am the only one doing any work on it.
I’ve never seen it that bad. I suggest you give IA a call.
