Thin white line and slight image shift when applying a red tint to an SVG in Perspective
Hi everyone,
I’m seeing a rendering issue when applying a tint to an SVG using the Perspective Image component.
Environment
  • Component: Image (ia.display.image)
  • Image source: SVG
Observed behavior
When I apply a red tint, a thin white vertical line appears along the right edge of the image. The image also appears to shift slightly to the left.
Applying a green tint to the same SVG does not show this issue.
What I’ve tried
  • Using a black version of the source SVG: the white line still appears with the red tint.
  • Setting the component’s position and dimensions to integer values.
  • Changing the overflow setting.
None of these changes resolved the issue.
My expected result is for the tint to change the image color without introducing a visible line or changing its apparent position.
Has anyone encountered similar behavior? Could this be related to the SVG itself or the Image component’s tint rendering? Are there any additional settings or tests that would help narrow it down?
I’ve attached the original SVG and comparison screenshots with red and green tints.
Thanks!
Hello @sylee,
Would you be able to re-attach the original SVG as I only see the screenshot of the behavior that you are seeing? I would like to run some tests with your SVG on my end. Are you seeing this behavior with any other SVG images or is this occurring only with the specific SVG that you have mentioned?
Hi, apena.
ACBACB_TestVCBVCB_Test
The same issue occurs with all of these images.
