Time ignition perspective
Hello, I would like to trigger an alarm if I detect engine malfunctions between 7:00 a.m. and 9:00 p.m.
For example if stpValue >100 and the time is between 7h00 and 21h00 then I trigger an alarm.
But I don’t know how to know if the time is on the interval of 7:00 a.m. and 9:00 p.m.
You could set up a normal alarm with an execution mode of Above Value for your setpoint, then place an expression binding on the Enabled property that looks something like:
timeBetween(now(), "7:00:00 am", "9:00:00 pm")
Thank you Sir.
That is mean
if moteur1 = 1 and setpoint = 1 and timeBetween(now(), “7:00:00 am”, “9:00:00 pm”)
alarm is enabled
else:
alarm is not enabled
I can do that?
If moteur and setpoint are boolean (True or False only) then you can use:
if moteur1 and setpoint and timeBetween(now(), “7:00:00 am”, “9:00:00 pm”):
    alarm is enabled
else:
Note the ‘:’ at the end of the line.
Please use the </> code formatting button when posting code. It will indent properly (important for Python) and give syntax highlighting. You can use the 🖉 edit link to fix your post.
Be careful. You’re starting to mix scripts and expressions.
moteur1 && setpoint && timeBetween(now(), “7:00:00 am”, “9:00:00 pm”)
Thank you, I solved it
Thanks, Jordan. Can you clarify what’s wrong with my approach? timeBetween returns a boolean so why would my script be incorrect?
timeBetween is an expression language function but you wrote Jython script syntax.
I was just gonna requote myself. :wink:
