Time library of type str
In the script console this script return this result. Why the time library is of type str?
import time
print dir(time)
print type(time)
['add', 'class', 'cmp', 'contains', 'delattr', 'doc', 'ensure_finalizer', 'eq', 'format', 'ge', 'getattribute', 'getitem', 'getnewargs', 'getslice', 'gt', 'hash', 'init', 'le', 'len', 'lt', 'mod', 'mul', 'ne', 'new', 'reduce', 'reduce_ex', 'repr', 'rmul', 'setattr', 'str', 'subclasshook', '_formatter_field_name_split', '_formatter_parser', 'capitalize', 'center', 'count', 'decode', 'encode', 'endswith', 'expandtabs', 'find', 'format', 'index', 'isalnum', 'isalpha', 'isdecimal', 'isdigit', 'islower', 'isnumeric', 'isspace', 'istitle', 'isunicode', 'isupper', 'join', 'ljust', 'lower', 'lstrip', 'partition', 'replace', 'rfind', 'rindex', 'rjust', 'rpartition', 'rsplit', 'rstrip', 'split', 'splitlines', 'startswith', 'strip', 'swapcase', 'title', 'translate', 'upper', 'zfill']
<type 'str'>
Hmm, this probably means you've redefined time somewhere.
Thats the strange part. This is a brand new gateway and I am running this code in the script console. I really don’t know where it would be redefined.
Press the restart button in the script console editor and see if that helps?
Thanks that did the trick.
