Every time I load my chart I initially get an error. It lasts for a couple seconds and then the chart loads. I there anyway to avoid this?
You could try looking at bindings and if persistent is set or not. It really depends on how you are getting data... no telling by just a screenshot.
I know I ran into the same issue, if persistent doesn't do it, maybe opt out of the overlay.
I would also try and find the error and if possible, fix that. Perhaps it's getting the wrong type of data and you might be able to handle that gracefully. You can get the error by hovering or clicking on the red circle, if time permits. Otherwise, maybe try and reproduce within the designer.
I appreciate your suggestions but nothing seems to work and I can't catch the error and it isn't logged. I am trying to figure out how I can maybe use some error handling in the binding.
