Time Series Chart - forcing the X-axis range and grid offset
I've a couple of problems:
By default the Time Series Chart uses the first and last values of the first column of data as the range for the x-axis. I want to display a full 24 hours starting on a particular hour (typically midnight or 8 a.m.).
  1. How can I specify the x-axis range? (I've fooled it by adding force24HourXAxis series with two points (startTime, 0) and (endTime, 0) but this is now showing up as "Timestamp" on the x-trace and I don't want that.)
  2. The gridlines are offset by half an hour. The XY Chart has an offsest function to fix this. Is there one for the Time Series Chart?
Mine are all like that too.
Maybe some are worse since I used discrete steps for some graphs.
8.1.19 is the version I am using.
Either way though, it is offset.
