Time Series Chart: Selectable Pen/Tag Visualization Based on User Requirement
Hello everyone,
I am using the Time Series Chart component in Ignition 8.3 to visualize batch data. The data is being fetched from the database using a Named Query, which is bound to the chart’s data property.
Currently, the chart displays all the data columns from the table, but I would like to make the data selectable based on user requirements.
For example, if the dataset contains tags such as PT101, TT101, and TT102, I would like the user to be able to choose which tags to visualize—similar to how tag selection works in the Power Chart component.
Has anyone implemented something similar using the Time Series Chart, or does anyone have suggestions on how this can be achieved?
Below is the query I am currently using:
SQL
SELECT TOP 1000
t_stamp AS time,
PT101,
SOV102,
SOV101,
TT101,
TT102,
TT103
FROM Batchdata
WHERE t_stamp BETWEEN :startDate AND :endDate
ORDER BY t_stamp
Show more lines
I have also attached screenshots of the data table for reference.
Any guidance or ideas would be greatly appreciated.
Thank you in advance.
I believe you could use "QueryString" parameters in your named query to pass in a list of fields.
This is the ideal use case for the DB table historian:
Meh. It only accepts one query parameter.
