Timer in Client event scripts
I am running a timer script in Client event scripts
Once the screen lock in Client whether timer script will still running??? Or it will stop???
Still running, unless the computer goes to sleep.
Is there any way to stop it when its locked?
And resume when its unlocked
I don’t know if Windows exposes screen locked status in any way java can read. You cannot stop the event from running, by you could check a boolean to skip the processing when locked. The trick will be to determine from within Ignition if the screen is locked. I don’t know that answer.
For production HMIs, I set the desktop to presentation mode, so the screen with neither blank out nor lock. If not a production HMI, you probably should not care that the screen is locked.
He may just mean the Vision Lock Screen, which is triggered by a script that looks at the inactivity timer by default. He could set a Boolean and skip processing as you suggested if that’s the case.
Yes i have found a way
In first line i need to use this one condition
If not system.security.isScreenLocked():
Its correct right?
Yeah that should work.
