I have a very specific problem with the time series plot. I have two axes, one on the left and right, with different scales. I have two data sets, one for each axes. Each dataset has a target setpoint which I am displaying with a horizontal line. My idea was to mess with the axes ranges, so that the setpoint for the two different data sets line up (i.e. there is one line that on the left hits one data setpoint, and on the right hits the other). I would love to show a screenshot here but I am unable due to company policy. I actually have solved this with some simple maths, but the issue is that ignition is changing the max and min to be nice round numbers. I don’t want this but I cannot see an option. I don’t mind if the actual markings are rounding, i.e. lets say the maths works out that the max of the first axis needs to be 157.21, ignition will just make it 200, which throws off the ratio. Now what I want is for the highest marking to be something like 150, and then the axis can extend slightly beyond this. Is this possible?
I have tried this, but unfortunately the same issue occurs where the max and min are determined by ignition and not the numbers I put in. It still uses an arbitrary max/min which is nice and round but throws off my axis size.
What I have noticed from messing around with this, is that say I have 10 tick marks on each side. The top tick mark for the left and right axes are not aligned at all. Same with the bottom mark. I don’t understand this, and there seems to be no options to fix it. Ignition seems to be picking an arbitrary spacing between the last tick mark and the end of the axis scale.
