How can i change Tint color for same Valve with two different Boolean Tags?
For Example Tag1 green ,Tag2 Red
Create a custom property on the image, I called mine ‘tint’.
Then add this code to the Custom Property ‘tint’
binEnc({booltag1},{booltag2})
This will return the results 0 - 3.
Then check box Tint Filter under Image Manipulation.
Below that is Tint Color, bind Tint Color to the custom property ‘tint’.
Then add the rows below that.
1 = green
2 = red
Cheers,
Chris
