Saludos su ayuda por favor estoy tratando de ingresar un nuevo Tag OPC pero tengo un tipo de dato que es UsInt y desconozco su Sintaxis del tipo de dato. Ejemplo: para una tipo de dato BOOLEANO se utiliza como sintaxis X, para un tipo de dato INT se utiliza I. espero a verme explicado.
Please use the 🖉 edit link to add an English translation of your question and you will get much more help.
Greetings, your help please. I am trying to enter a new OPC Tag but I have a data type that is UsInt and I don't know its data type Syntax. Example: for a BOOLEAN data type, X is used as syntax, for an INT data type, I is used. I wait to see myself explained.
So you're trying to create an OPC Tag for some type of Unsigned Integer.
What protocol are you using here, it seams like perhaps it's Modbus.
Let us know what type of device, and the driver that you are using to connect to the device.
