Title in Flex Container
I just added a label inside a Flex Container tos how the tittle
In vision you could add tittles:
Is there other way to do it in perspective?
If no I stick with the label.
Cheers
There is no other way to give a Flex Container a title so you would have to use a Label, yes.
You can achieve the same thing using css styling. you need the border and some absolute positioning for the label and set zindex properly.
a good example of some css on this ( you can mostly ignore the html, but the classes need to be properly applied to parents and components)
Thank you guys, will try with the absolute positioning for the label. Cheers.
You can also just nest your flex row container containing the checkboxes inside a flex column container. Style the flex column container to have a border or show up as a surface, which you can do either via css or via the style editor when the flexbox is selected. Then drop in a label in your flex column container above the flex row container.
Good idea!
Thanks guys, is working, for this solution just added a label on the flex container with an absolute position with margin top 0 as one of the solutions proposed
There is a css solution for this, but that looks better with less effort :stuck_out_tongue:
I suggest you add a style gap:5px to your flex reptear btw, and maybe reduce the spacing between the label and checkbox
adding the gap make the checkboxes look much better, thanks!
Giving the a class like checkboxNoPadding to the checkbox and adding this css tot he stylesheet. It will also reduce the padding between checkbox and label.
.psc-checkboxNoPadding.ia_checkboxComponent .checkbox-input-label--right{
    padding-left: 1px;
for a list of checkboxes like that the padding should really make it clear which label is with which box
Thanks Victor!, yes the gap already help a lot making clear wich label goes with wich box. I will try this extra bit css too.
