ToddySoft Connect 1.3.0 is out. Since I've only ever posted about single modules here, this is the full list of what we offer for Ignition by Inductive Automation®, plus what's new in this release.
Driver modules
Each driver is its own module, with one build for 8.1 and one for 8.3.
- Beckhoff ADS: TwinCAT 2 and 3, including Secure ADS
- Siemens S7: S7-300, S7-400, S7-1200 and S7-1500 (S7Comm & S7CommPlus)
- Siemens S7 Web API: S7-1200 and S7-1500
- Bosch Rexroth ctrlX: ctrlX CORE over REST
- Schneider Electric UMAS: Modicon M340 and M580
- IEC 60870-5-104 (new in 1.3.0): see the IEC 104 thread
- IEC 61850 (new in 1.3.0): MMS client for IEDs
- Modbus/TCP and EtherNet/IP: available only as part of the All Drivers Package
New in 1.3.0
- IEC 61850: reads and writes data attributes, and operates control objects with direct or select-before-operate control. It can take values from the IED's report
control blocks instead of polling. The data model is browsed from the IED itself, so you need no SCD or ICD file.- Triggered groups: a group of tags is read together whenever a trigger tag changes, instead of at a fixed rate. This works in every module except the two IEC
drivers, which already work report-based. - Device discovery on 8.3: Modbus/TCP and UMAS devices appear in the Discover Devices dialog. If the gateway runs in Docker, a discovery agent on the plant network
finds the devices for it. - License diagnosis: the gateway shows why a device is or isn't licensed and can create a report for our support.
- Requirement change: the 8.1 modules now need 8.1.33 or later (Java 17).
For an experimental "Ignition on Bosch Rexroth CtlrX" deployment we even have a CtrlX Native driver that directly accesses CtrlX' real time layer for Ignition 8.3
Every module ships with a manual and release notes in English and German. Free trial licenses are available on request.
Release notes: ToddySoft Connect 1.3.0 Is Out, and a Year-End Offer for Your 2026 Budget — ToddySoft
All Ignition modules: ToddySoft Connect — Ignition Modules — ToddySoft
Year-end offer
New module licenses ordered by December 18, 2026 include twelve months of maintenance and 10% off the license price. The full terms are at the end of the release notes linked above.
Questions and protocol requests are welcome here or at contact@toddysoft.com.
Christofer Dutz, ToddySoft GmbH
