TOF Style timer with tags (no PLC)
I have two tags, I want tag A and B (bools) to go high at the same time, but I want tag B to go off 30 minutes after tag A does. What is the best way to accomplish in Ignition, no PLC involved in this application.
What ever event occurs to turn off A and B, have it write a timestamp to a tag. Then you can compare now to that time plus what ever offset you want and keep B true until then.
The same would work for a TON configuration, you would just keep B off until the set time elapsed.
I would use Louis' approach, but have the event on tag A add the time interval to now() before writing to the timestamp tag, so that timestamp tag has the cut off time. The expression tag for B would then have:
{[.]A} || dateIsAfter({[.]CutoffTS}, now())
Adjust the now() fragment for how precise you want the cutoff.
There is nothing new under the sun... lol
and also this one for a bit finer precision.
TimerUDTmillis.json (2.1 KB)
