I’m working on an upgrade from Ignition 7.9.10 to 8.0.10 (on a test server for now).
In 7.9.10 we have used the margin property of a Toggle button to control the position of an image on the button. This doesn’t appear to work in 8.0.10, although text in a toggle button does change position depending on the margin.
Is this known behavior? Is there another way to control the position of an image in a toggle button? The image was placed using the ‘Image Path’ property of the toggle button.
Toggle Button in 7.9.10. The label is a separate component on top of the toggle button.
Toggle Button in 8.0.10
