Toggle Button Text Label Over Image
Hello,
We are building a Frontend application with Vision, and we are trying to add a label text over the image on the toggle button. At the moment we can't. We need to use a toggle button instead of a button because our logic flow needs this component to display the correct flow states.
This is the result that we've.
And this is the desired result.
Thanks in advance
Use a template, put your background in as an image component, do the toggling with a toggle button with a fully transparent background so the image shows through?
