Toggle fullscreen mode through a button in app
Hi there,
I'm looking for a way to switch to fullscreen mode on my perspective app so that the operators have no access to the browser settings. I want to trigger the event on a button click. What properties do I have to use to do that ?
Thank you.
I doubt there's any built-in way to do that.
Probably not even a supported/clean way, actually.
And maybe no way at all.
I heard it is possible, it's just that I can't get the information.
https://docs.inductiveautomation.com/display/DOC81/system.perspective.workstation.toKiosk
kiosk mode?
onyl works with the workstation app tho, if you use a browser its not possible
I believe if you use Workstation, there is an option to switch between Kiosk mode and Windowed mode through an action - I haven't tried this myself yet, though.
https://docs.inductiveautomation.com/display/DOC81/Component+Events+and+Actions#ComponentEventsandActions-WorkstationModeAction:~:text=all%20available%20themes.-,Workstation%20Mode%20Action,-The%20following%20feature
Perspective allows for it via the Fullscreen Action. Note that there is no scripting equivalent because browsers require this action be DIRECTLY triggered by a user action. You should also note that by design - the browser will always allow a user to escape fullscreen mode by pressing Escape.
So there is no way to block in fullscreen mode ?
No. Browser security requires that a user always be able to escape any override of default behaviors.
