Is there a limit of how many tags in a single system.tag.readBlocking? If so, I think I might have reached it. The error I'm getting is: "java.util.concurrent.TimeoutException: null"
I'm trying to read 2.2 million tags. What's the tag limit? How many is too many for such a call?
There's no explicit quantity limit, but I'm gonna guess you've hit a practical limit. Unless you are trying to do this from the designer or a Vision client, in which case you've probably hit the 60 second timeout on traffic between designer/client and the gateway.
It is running this from the gateway script. This is the error on the log.
Scripting[system_util_tag] 09Nov2026 21:58:15 Error during blocking read of tags through scripting.
at java.base/java.util.concurrent.CompletableFuture.timedGet(Unknown Source)
at java.base/java.util.concurrent.CompletableFuture.get(Unknown Source)
at com.inductiveautomation.ignition.gateway.script.GatewayTagUtilities.readBlockingImpl(GatewayTagUtilities.java:246)
at com.inductiveautomation.ignition.common.script.builtin.AbstractTagUtilities.readBlocking(AbstractTagUtilities.java:510)
at jdk.internal.reflect.GeneratedMethodAccessor90.invoke(Unknown Source)
at org.python.core.PyReflectedFunction.__call__(PyReflectedFunction.java:190)
at com.inductiveautomation.ignition.common.script.ScriptManager$ReflectedInstanceFunction.__call__(ScriptManager.java:553)
at org.python.core.PyObject.__call__(PyObject.java:461)
at org.python.core.PyObject.__call__(PyObject.java:465)
at org.python.pycode._pyx266356.export$7(:97)
at org.python.pycode._pyx266356.call_function()
at org.python.core.PyTableCode.call(PyTableCode.java:173)
at org.python.core.PyBaseCode.call(PyBaseCode.java:168)
at org.python.core.PyFunction.__call__(PyFunction.java:437)
at org.python.core.PyMethod.__call__(PyMethod.java:156)
at org.python.pycode._pyx266352.cache_tags$18(:548)
at org.python.pycode._pyx266352.call_function()
at org.python.core.PyBaseCode.call(PyBaseCode.java:187)
at org.python.core.PyFunction.__call__(PyFunction.java:449)
at org.python.core.PyMethod.__call__(PyMethod.java:171)
at org.python.pycode._pyx266352.cache_provider_configs$15(:486)
at org.python.core.PyBaseCode.call(PyBaseCode.java:306)
at org.python.core.PyBaseCode.call(PyBaseCode.java:158)
at org.python.pycode._pyx266370.handleMessage$1(:10)
at org.python.pycode._pyx266370.call_function()
at org.python.core.PyFunction.function___call__(PyFunction.java:474)
at org.python.core.PyFunction.__call__(PyFunction.java:469)
at org.python.core.PyFunction.__call__(PyFunction.java:464)
at com.inductiveautomation.ignition.common.script.ScriptManager.runFunction(ScriptManager.java:847)
at com.inductiveautomation.ignition.common.script.ScriptManager.runFunction(ScriptManager.java:829)
at com.inductiveautomation.ignition.gateway.project.ProjectScriptLifecycle$TrackingProjectScriptManager.runFunction(ProjectScriptLifecycle.java:868)
at com.inductiveautomation.ignition.common.script.message.MessageHandlerRunnable.run(MessageHandlerRunnable.java:121)
If there is a limit, it would be nice to know what that is, so I can slice the list of tagpaths into a smaller list.
You've hit a timeout, so as PTurmel says, there is no "limit", however depending on hardware this will take too long and hit a timeout limit. We can't answer the value of how many to batch this down to because it is very dependent on your hardware/network. Running this on a Raspberry Pi or a datacenter cluster will give very different results. 2.2 million tags might be OK for a cluster, but 1000 tags may be too much for a RPi.
What you will have to do is testing on your side to determine how many tags you can read without overloading your network/server, then add in some margin and set that as your batching value (and gracefully handle any Timeout's with a retry on smaller batches).
