I have worked a lot with dataset tags, and found it tedious to convert excel files to csv, convert csv to plaintext, and then manually add the additional little bit of text at the top of the csv file, and then copy that text and paste it into the dataset tag from clipboard. I wrote a small web app that makes this process a lot easier, just upload your excel or csv file and it will automatically generate the plaintext that you can copy and paste directly into ignition. Hope this helps.
