Does anyone else get annoyed with the tooltip always covering up what your are trying to work on?
+1
+1
Run one of the following script in the Script Console in the designer
To set the tooltip delay:
from javax.swing import ToolTipManager
tipManager = ToolTipManager.sharedInstance()
tipManager.setInitialDelay(2000)
To turn off tooltips altogether (Do this to keep from getting tooltips in the tag browser)
tipManager.enabled = False
What would be kind of a good middle-ground solution is making sure the tooltip is always at the top so it doesn't cover the current line of code you're writing ?
Something similar to what already exists for Perspective when it comes to tooltips but I do not know if that's doable in Swing.
yes, this and when tabbing from a style keyword and it moves up in the sorting, so you don't actually tab into the value of it.
or... hit the [Esc] key and it goes away.
I never knew this.. thanks!
