Tooltip in perspective
Most client ask for standard tooltip in perspective. I try to create tooltip with mouse event and a simple popup (without any title bar) but the end result is not good for three reasons :
1 - I can’t setup some delay after mouse over object to show tooltip.
2 - Move over mouse over tooltip cause Mouse leave event triggers for object and it closes the popup.
3 - Repeating those setup for each object is really time consuming. (mouse events, popup,…)
So I believe it is only can done in core functionality of perspective.
Is anyone have better idea to create popup?
Or is there any plan to finally add this feature?
Tooltips are definitely on the agenda to add first party.
https://inductiveautomation.canny.io/ignition-features-and-ideas/p/add-tooltip-text-property-to-perspective-objects
Any estimation?
I hope not until release of in 8.2.0.
The Numeric Entry Field has a tooltip built-in. I hope its implemented in a better way than that. Because, Numeric Entry Field tooltip. Doesn’t work well in a pop-up.
I hope its implemented in a more succinct and global way way.
Any chance this might be in 8.2
8.2 could be a year or more away as there is an arbitrary number of minor 8.1.x versions before that :man_shrugging:
any possibility this feature will be added before 8.2
Tooltips will almost certainly land before 8.2. Probably in the next ~months.
Is it available for every objects? like svg shape for example.
As I understand it, every Perspective component with a meta prop can have an individual tooltip.
Do we have CSS roles for this new tooltip feature in global CSS file of perspective?
There is a very simplistic entry added to the CSS files, but you’re able to control the appearance at runtime via props within the tooltip property object. The tooltip itself has it’s own style object to allow for most anything you could want.
Great. I really can’t wait to see it.
