Top border of selection box in ChartRangeSelector doesn't show up in 8.1.x
It seems in 8.1.x the Top border of the selection box in ChartRangeSelector always hidden.
I submitted a bug ticket regarding this :+1:
A workaround to get that pesky line visible would be editing the the theme of your Perspective project (by default it is the light theme) located in C:\Program Files\Inductive Automation\Ignition\data\modules\com.inductiveautomation.perspective\themes .
Edit the CSS file and add the following lines:
.ia_brush > rect:last-of-type {
    transform: translateY(1px);
Then you may also need to clear you .ignition cache.
Thanks. But do you plan to fix it by default in 8.1.6?
Still to be determined at this time. I will update this thread when/if a stable version includes a fix for this.
