Hi everyone,
I tried connect TopServer V.6.8.797 but show ‘Faulted’. Ignition version 8.0.12. OS Win7 x64.
FAULTED
status=Bad_CertificateUriInvalid, description=The URI specified in the ApplicationDescription does not match the URI in the Certificate.
UaException: status=Bad_CertificateUriInvalid, message=The URI specified in the ApplicationDescription does not match the URI in the Certificate.
at org.eclipse.milo.opcua.stack.core.util.CertificateValidationUtil.validateApplicationUri(CertificateValidationUtil.java:326)
at com.inductiveautomation.ignition.gateway.opcua.client.ClientManager.initializeObject(ClientManager.kt:123)
at com.inductiveautomation.ignition.gateway.opcua.client.ClientManager$initializeObject$1.invokeSuspend(ClientManager.kt)
at kotlin.coroutines.jvm.internal.BaseContinuationImpl.resumeWith(ContinuationImpl.kt:33)
at kotlinx.coroutines.DispatchedTask.run(DispatchedTask.kt:56)
8.0.12 (b2020042115)
Azul Systems, Inc. 11.0.6
Could you help me this issue?
Thanks!
